Tell me more ×
I have a Nissan Micra (UK, 51-plate, 2001 model) that I have been using to drive to work on a daily basis - 10 miles each way a day on a variety of roads - streets, main roads, main roads in traffic, motorway and dual carriageway. Recently while leaving home and work I've noticed the engine temperature raise from starting point to half-way (which I've seen as "normal" temperature") and creep near to the red and then drop back down to normal levels again. It only seems to happen when stopped in traffic - once I get onto the motorway it drops down quick - I guess this may be down to airflow cooling the car?
I've checked the coolant levels and they look fine. When I get home I hear a "ticking" from the engine which I believe is just the engine cooling down. What could I do or need to check?
1 Answer
It could be your thermostat - if it is not reading temperatures properly it may not trigger your fan until temperatures get really high.
Being stationary with the engine running is usually the time when this can happen, as there is no cooling airflow until the fan comes on.
Run the engine with the bonnet (hood for US-ians) and see when the fan starts - is it when the temperature is just over its normal level, or does it wait until the engine temperature is very high?
Another simple thing to check is the oil level - if this is too low then it can lead to overheating. Make sure you have enough oil in the system.
Rory sounds right to me: this sounds like exactly what would happen when the underhood temperatures get high, triggering the fan. From looking at the pictures, there isn't a lot of room for air to move around on its own. It seems like the engine is going to only shed heat with the fan running or with airflow (which is exactly what you've seen). – Bob Cross Oct 15 '12 at 11:59
Seems about right to me. Interestingly, on my Jeep (which had a similar problem once), I found that revving the engine while still actually helped the temperatures by getting the fan spinning faster. – Iszi Oct 15 '12 at 18:13
I would question if the fan is doing anything at all. On most cars, at speed the volume of air moving through the radiator just from moving is greater than the CFM rating on the fan. – NitroxDM Nov 5 '12 at 2:57
At speed the OP doesn't have this problem, probably because the airflow is fine. At low speed the fan is essential! – Rory Alsop Nov 5 '12 at 7:28
