Recently they replaced my stock radiator with aftermarket one (at dealership, so I hope they knew what they were doing), and since then I feel that a car is not warming up enough.
Even if I warm it up completely at garage - as soon as I start driving temperature drops. Driving at high speed drops it even more, when temperature outside is cold it gets worse too. I don't have precise temperature gauge though (only 4 digital bars on gauge) so I can't be sure.
This new radiator is smaller/thinner. Can a radiator be too "good" and cool down a car too much? Thermostat should completely disconnect radiator from the circuit if a car is cold, isn't it?
(at dealership they say it all behaves as it should, car is not over-cooling)
Car in question is Honda Prelude'92.
link|improve this question
feedback
up vote 16 down vote accepted
If the thermostat is operating properly the radiator will only come into play when the thermostat opens, when the engine is at normal operating temperature (around 190 degrees, give or take). Adding a gigantic radiator won't make a bit of difference because if the engine gets too cold, the thermostat will close, causing the engine to heat up again.
In the winter, the cabin heater will draw around 20% of the engine's heat in order to heat you. This will cause the car to heat up slightly slower, but once it's warm it will stay that way.
It's possible that the thermostat isn't fully closing when you are driving, but works ok at idle. You might consider getting a high quality thermostat and replacing the existing one. It's also possible that the coolant temp sensor is on it's way out..
On the highway, a car produces lots of heat (at a higher RPM), which indicates to me that the thermostat is opening more (or failing to close properly) at higher RPMs since you are seeing a temp DEcrease at speed. Again, a new high quality thermostat should fix this.
link|improve this answer
Looks like a car thinks it is cold and starts warming up the engine increasing idle rpms up to 1800rpm from default sub-1000 (this happens at traffic lights after driving for some time), so it is not something I can just ignore. – serg Mar 17 '11 at 20:38
You can test a thermostat by dropping it into boiling water to see if it opens. – chris Mar 17 '11 at 20:39
@serg the engine running cold would not cause the car to idle at 1800 rpm. That's too high, that sounds like an unrelated problem. – Larry Mar 17 '11 at 23:53
I agree that it sounds like a thermostat. However, I have run into a situation where I had too much cooling... It was 40 degrees below, I was driving on the highway, and the 1.9L engine just couldn't keep up with providing enough heat to the cabin. So I turned on the propane furnace. :-) It was a VW camper van, water cooled. – Sean Reifschneider Mar 22 '11 at 11:17
@Larry Depends on the car. On one of mine the idle speed and engine timing are linked to coolant temp. It'll idle as high as 2500 rpm initially on sub-zero days. On a typical spring/fall day it starts out at around 2000. – Brian Knoblauch Jun 30 '11 at 16:15
feedback
The thinner radiator might make it easier for the cold air to flow through the engine compartment.
(The radiator itself wont cool an already cool engine at all if the thermostat is intact.)
In cold environments it is often necessary to use a grille cover to limit cold air flow to the engine.
Grille covers are especially necessary with small diesel engines not producing enough excess heat.
A typical DIY solution is a piece of cardboard.
feedback
The thermostat controls the temperature in the engine. It opens at a set temp, 195 degrees for example and allows coolant to flow through the radiator. If it's stuck open it would allow coolant to circulate through the radiator all the time not allowing the car to heat up properly. The complaint usually is the heater isn’t warm enough. If the thermostat sticks closed (obviously not in this case) the engine would overheat.
Too big of a radiator won’t cause the car not to warm up, however to small of a radiator could cause it to overheat.
feedback
The temperature drops when you start driving because you have more air coming into the radiator (the car is moving at higher speed). The same thing happens to my Acura Legend ('87). It'll be coolest when driving on the freeway, but if I'm stopped at a light for a while, the temperature may rises (on a hot day). Both my fans (radiator and condenser) work.
feedback
Why was the rad. replaced? If because it was faulty it might have taken out the thermostat as it went. As others have said above the radiator itself can't overcool with a working thermostat.
feedback
or
required, but never shown
