Sign up ×
Here is the description of my problem occurring on my Skoda Fabia 1.4 MPI car, built in 2003:
  • The green dashboard cluster illumination (that illuminates the speedo, rev counter, time and miles) is fully illuminated when I turn the lights on while not in ignition.
  • The green dashboard cluster illumination becomes very dim (but stays on) when I turn on the ignition, or start the car.
  • Dashboard warning lights (ie: battery indicator) work perfectly.
  • Almost none of the cockpit guidance lights work (ie: charger, temperature control dials, electric windows). The notable exception is that the guidance light on the light switch dial (next to the dimmer) does work.
  • The light dimmer has no effect whatsoever on anything.
  • My external lights seem to work fine always, as do the curtesy internal lights (ie: the bright white light above the centre console, and the bright white light in the boot).
  • However, the festoon-based number plate lights at the back of my car do not work, at all.
Based on the above, does anyone have any idea whatsoever as to how I could solve this problem? I wonder if it is the reason why I've recently had to purchase a new battery despite the fact that I had already bought and installed one myself half a year ago.
Here's a bonus oddity: If I turn the lights on without ignition, and someone closes or opens a door, then the green dashboard cluster illumination temporarily dims and then, after half a second, returns to being fully illuminated.
Any advice is much appreciated!
Which fuse? I have a similar situation and all fuses look fine. Thanks, Paul – user2300 Oct 13 '12 at 12:30
up vote 2 down vote accepted
Turns out the fix required the replacement of a fuse.
