Tell me more ×
I recently picked up a piece of metal in my tire, leading to a flat. The mechanic said he could not plug the tire, and that a "hot patch" was required.
What is a hot patch, how is it applied, and when is it required?
1 Answer
I have never used any of these techniques. This is how is was explained to me by an "old guy" who by the way, had never done it either. The shop I worked in had been around for years and we had stuff that was never used. One was the vulcanization kit. Maybe it was an excuse to sell more tires or liability isses. Years ago tires were always patched.The repair was made by "vulcanization". The process was either chemical,thermal or a combination of both. In the chemical process either two chemicals were mixed and they generated heat or a rubber softening chemical was used to soften the rubber. The thermal method involved a hot metal iron. The patch is clamped in place intil it has set. The end results were all the same, rather than the repair being glued in place the repair was basically a weld with rubber. Maybe with the cost of tires it is gaining popularity again.
