My 2003 Jetta TDI check engine light recently came on, and a scan by Advance Auto revealed code P0401 -- EGR insufficient flow.
I took the vehicle to the local TDI guru, who gave me the option of removing the EGR from the system entirely, and replacing it with a race pipe (and a rechip to prevent the CEL from coming on). The FAQ at Dieselgeek explains that there is no disadvantage to removing the EGR, and it saves the vehicle from future clogging, and with the addition of a race pipe, it gives +3hp over 3000rpm.
This site explains that:
The main purpose of the EGR is to reduce NOx emissions produced during diesel or gasoline engine combustion.
... it lowers peak combustion temperatures and reduces NOx emissions anywhere from 50%-75% vs. a non-EGR system.
And this site says:
Disabling the EGR increases NOx emissions, but also reduces particulate emissions.
And this site says:
[Soot buildup inside the manifold] further reduces engine performance and airflow, which in turn reduces combustion efficiency and increases other unwanted emissions, principally Co2 and particulate emission.
So this seems to imply that particulate emissions (and Co2) go up only after a build-up of soot occurs, and engine performance is degraded, but not as a direct result of removing the EGR.
But then later says:
"All EGR systems reduce air flow, combustion efficiency and consequently engine power"
What would be the complete effect of removing the EGR from this vehicle?
Not an answer, but as an alternative to messing with "chipping" to eliminate the CEL, you might see if there are simple ways to replace the sensors that would cause the CEL with simple dummy circuits. Sometimes just putting the appropriate resistor across the terminals can trick the computer well enough. – R.. Jul 26 '12 at 6:04
@R..: There are people who have done that, but I'll be re-chipping anyway for some bigger injectors, so that's not really any extra hassle. It's been something on my to-do list for quite a while, this recent EGR failure is just an excuse to do it all at once now. – Flimzy Jul 26 '12 at 6:23
Disadvantage is that tampering with emissions systems makes a vehicle no longer street legal.
Other than that, it probably won't hurt anything at all.
I don't see how removing EGR will increase power though. EGR closes at high power settings anyways. The gain would be entirely from some other feature of the racepipe (perhaps it's bigger). The fact that there's no longer an EGR isn't going to make a difference.
"makes a vehicle no longer street legal" - quite correct, but this is hard to find and then prove so you can be left uncaught for decades, trust me. – Andrei Rinea Aug 27 '13 at 13:08
Indeed. When I bought my Eclipse I found that the catalytic converter was missing and the EGR was blocked off. It'd recently passed emissions in a nearby city that way (as those changes looked quite old) too! Apparently the visual was less than thorough and the exhaust passed the test despite missing those systems. First thing I did was to get a replacement cat! I didn't know about the EGR at first, but eventually I started getting CELs while decelerating off the expressway and a vacuum inspection revealed the blocked off EGR, which I then unblocked! – Brian Knoblauch Aug 27 '13 at 14:28
As a vehicle technician for BMW I can assure that it is good for your engine to get rid of EGR. EGR systems are there to improve the exhaust gas quality and slightly win a few miles on a tank (in theory). What really happens is quite different. Your oil will become polluted quicker, your manifold / intake will get clogged by excessive amounts of soot and eventually your car will become a big pollution mobile that isn't as fast as when you bought it. The people who know this solve this problem easily by disabling the EGR system on old cars. But on cars from 2004 and on, it can get more difficult because chip tuning might be needed. In any case, removing the EGR is a bit more harmful for the environment, but not as harmful as a clogged up diesel engine & disabling makes a lot of diesels pretty much indestructible.
With proper maintenance, the EGR system not only runs fine, but your engine runs fine as well. The EGR, as you've stated, is there to reduce emissions. Of the big three emissions from an automobile, the EGR reduces the worst one: NOx. NOx is what causes acid rain. It also tears up the lungs. At least CO is a silent killer. Getting rid of the EGR may make it run better in the short term, but doing proper maintenance is by far less costly to the environment. If you really want to get rid of it, install a cam with more valve overlap, so reversion can occur within the cylinder. – Pᴀᴜʟsᴛᴇʀ2 Aug 29 '15 at 10:43
Does EGR have the same negative impact on gas engine as in has on diesel (oil pollution, clogging)? – Dmitry Grigoryev Oct 16 '15 at 7:31
You might find this post about Dynamic EGR Control for TDIs on the TDI Club forums by Mark at Malone Tuning interesting. Mark reports on his experiments with the EGR system on a 2006 TDI. He reports that the stock EGR settings resulted in a faster warm up (less wear on the engine) and better fuel economy than he got with the EGR deleted or dialed back.
The EGR system does lead to carbon deposits in the intake and these can be greatly reduced by cutting back on the EGR amount after the engine is warmed up. He claims that maintains the environmental and longevity benefits of the EGR will minimizing the carbon build up.
I would strongly recommend against doing an "EGR valve delete" the EGR valve assembly includes and anti-shudder valve that also gives you a way to shutdown a runaway engine. Runaways are rare, but if not controlled they usually result in substantial engine damage.
nox has nothing to do with acid rains. sulfur dioxide does, that is produced by the converter in exghuast pipe. egr recycle hot gases that eat away valves and plug the the intake. delutes the incoming air by occuping space that could normaly be used with good air.
Please read this commentary on NOx over on the "Green" site. Also, this really doesn't answer the question at large. Please check out the Help Center for how Stack Exchange works. Thanks for being here and for posting. – Pᴀᴜʟsᴛᴇʀ2 May 7 at 2:33
Would have to disagree with your beliefs based upon the facts. – DucatiKiller May 8 at 0:15
