I replaced a cylinder head gasket on my 1993 Holden Apollo (Same engine as the toyota camry 5S-FE). However when I went to get TDC I think I may have forgotten to put the car in Neutral. Could this have caused any damage to the engine? The car won't start now that it's all back together and I fear something has gone wrong.
Tell me more
Motor Vehicle Maintenance & Repair Stack Exchange is a question and answer site for
mechanics and DIY enthusiast owners of cars, trucks, and motorcycles. It's 100% free, no registration required.
Leaving the car in gear should not have had any effect, when you turned the engine it would have simply turned the wheels. I suspect the distributor may be 180 degrees out but I need more information from you about the condition. |
Four stroke engines get to TDC twice during a cycle - if you timed the engine off the wrong one (TDC on exhaust cycle), the engine will not fire as the timing will be out by 180°. |
