What can be the cause of a vibrating steering wheel when driving faster than a specific velocity (let's said 60 mph). How to discriminate one cause from on other ?
up vote 6 down vote accepted
Vibration felt in the steering wheel is usually caused by the front tires out of balance. That's the first place to look, other possibilities include: broken belt in the tire, out of round tire, a bent rim, a bent or out of round hub, wheel bearings.
One of the things you can do to help narrow it down would be to rotate the tires, if the vibration in the steering wheel goes away then it's related to the tires or rims. It would be just as easy to have the tires balanced though.
Since I buy this car, I always had vibration. With different rim and different tires. Normally if the mechanics have done is work I had a bearing wheel changed. Do you have any example of what is a "bent or out of round hub" ? Thanks ! – aberation Jun 20 '12 at 22:40
@type4 The Hub rides on the bearing, and it's what the wheel bolts too so if it's bent then the wheel won't run true causing the vibration. – Move More Comments Link To Top Jun 20 '12 at 22:43
I had a bad vibration when cruising on highway, I did an alignment and changed my wheels bearing. The vibration was mostly gone but I got a "death wobble", which is a loud noise coming from the front at high speed. I changed my tie rod ends and steering damper, redone an alignment and now everything is fine.
I'll do what Larry suggest first, this are the cheaper and easier things to do than you look at other possibles causes.
