Tell me more ×
Just bought a used Honda Jazz 1.4 SE for my wife, and although it has a CD/Radio with an Aux button on it, there is no external connection I can see.
As she wants to be able to connect her iPod, I am looking at how to do this.
My background is in electronics so I'm more than happy to build circuitry if required, but am hoping I can just wire a headphone type plug into the stereo if possible.
Is there a socket I can get at, and if so does anyone have a wiring diagram?
up vote 3 down vote accepted
I was looking for the same thing recently on a 94 Accord (different radio harness). Just looked around again to see if there's a solution on the 03-07 Honda radios and here are the results:
On some units you can solder into the aux interface. Otherwise you can cheat the radio into using its CD/Nav/XM expansion plug as an aux input. This usually requires an additional part to convince the radio you're using an expansion, but my guess is that part is just shorting a few pins, so you could probably whip out your background in electronics and save the $.
Anyway I recommend starting here and/or googling "honda fit jazz head unit wiring diagrams." As a last resort, the radio accessories work. 20-60 USD, easier than hacking but audio quality is not great.
Actually I hadn't seen your link, but it looks like the same info so I'll delete mine off here. I just missed your final paragraph for some reason. – Rory Alsop Jun 13 '12 at 16:46
A variety of manufacturers sell a small transmiter that plays your ipod thru your radio.See if this model will work for you.enter link description here
On some models, the aux socket (3.5mm stereo) is next to the cigarette lighter under a flap. Took me ages to find too.
Sadly on this model there is no AUX connection, but I managed to wire one up as per the guidance on @Tyler's answer. – Rory Alsop Sep 2 '12 at 12:26
