For the past month or so my 2003 Honda Accord squeaks in the morning when I start driving to work. After a couple of minutes of driving the squeak stops. I'm pretty sure it's from the belt area. What can be causing this? How do I remedy it?
up vote 14 down vote accepted
Most likely cause for this is that you have some condensation built up overnight on either the belt or one of the pulley wheels, and until this has evaporated the belt will be able to slip a little, causing a squeak. Once the engine warms up, the condensation is gone.
With a new, well tensioned belt, this shouldn't matter, however belts age and stretch, which makes them more likely to slip.
The recommended fixes include:
  • increase the belt tension
  • replace the belt
or possibly just give the belt a good clean, but the first two are better solutions.
Here's an indirectly related question: mechanics.stackexchange.com/questions/543/… Same symptoms on a different vehicle: the belt was old. – Bob Cross Jun 7 '12 at 17:09
It's not just condensation that might cause this; if it's the alternator belt, increased mechanical force required to turn the alternator when the battery is at ~13v (after sitting overnight) rather than ~14v (after recently running) will affect slippage. Of course tensioning or replacing the belt should fix it anyway. – R.. Jun 17 '12 at 13:10
That and just overcoming the static friction of all the accessories upon initial startup, as well as the coefficient of friction of the belt itself will be lower when cold. – Nick Aug 1 '12 at 2:58
