Tell me more ×
The clamps that are attached to the car battery are corroded, I was told either of these liquids will work. Which one is better? Is there a how to guide on the exact steps I need to take? With my limited knowledge, I know...
Disconnect the battery (the order of the clamps matters I think?), Clean the clamps and ports, Wait, Reattach battery
1 Answer
up vote 2 down vote accepted
What about a can of battery terminal cleaner? Should be available at any parts store (aerosol can). That plus a wire brush has always worked for me. As far as order of disconnection / connection, ground/black/negative is the first off and last on.
You could try cola or baking soda and water. They should work, but I suspect no better than a can of terminal cleaner. The cola will get rid of the corrosion but leave your terminals sticky. Maybe in an emergency, as Rory suggests, cola. Be careful with liquids around a battery, a short will ruin your day.
Definitely use terminal cleaner - although if you are out in the middle of nowhere and can only find a can of coke then it can help remove gunk and corrosion in an emergency. Would be a weird kind of emergency though :-) – Rory Alsop May 28 '12 at 16:13
Just he answer I was looking for! – ironcyclone May 29 '12 at 16:28
