I'm looking for a chart that will tell me the resistance values for each fuel level. There are a few such charts like that for resistance readings on coolant temperature senders. Does anyone know of one for the fuel level sender as well?
Tell me more
Motor Vehicle Maintenance & Repair Stack Exchange is a question and answer site for
mechanics and DIY enthusiast owners of cars, trucks, and motorcycles. It's 100% free, no registration required.
Fuel level senders, when operating normally, produce a resistance value that is directly proportional to the level of fuel in the tank. The value should change smoothly as the float on the arm goes up and down. You should see no sudden jumps in resistance. If a sender is bad, it can show the gas level as full, empty, or sporadically jumpy. Is this the problem that you are trying to diagnose? |
