Take the 2-minute tour ×
In another forum someone said "Screen down the fillneck may be partialy plugged up with matter." Is this something a neophyte can change or fix himself, or should I take it to an auto shop? How can I get to this screen to see if it is clogged or blocked?
I have a car that does this too, but only at certain stations and even then only when I put the nozzle into the filler neck as far as it could go. When I backed it out 1/2 to 1 inch it filled fine. –  Wulfhart May 23 '12 at 16:10
add comment
This is probably something you should take the car to a shop for. It sounds like a problem with the evaporative emissions system.
Your tank is a completely sealed system and when you are pumping gas it needs a way to vent the gas fumes from then tank because the gas flowing in pushes the fumes out. There are vent lines and solenoids that run to a charcoal canister which is usually in the front of the car. If there is something wrong with one of these solenoids or the charcoal canister itself it, will prevent the fumes from escaping and could cause the problem you are describing.
Thanks, I'll take it in and post back later. –  NealWalters May 23 '12 at 21:40
add comment
up vote 1 down vote accepted
I finally took it in to a Toyota dealership. They said it was the overflow control valve (OCV); it's inside the gas tank, and requires replacing the entire gas tank, about $1000.
As a side note, this sounds like something that should be covered under warranty on a 2010 vehicle. –  Bob Cross Jul 6 '12 at 19:35
add comment
