I am using Honda CB Unicorn 150cc.
Last day I had to ride my bike through water, after which none of the electricals were working. Only Head lamp will work while the engine is on. After when I removed and connected spark plug, The issue was solved.
After that I had to drive through water again, and the same problem. I tried to reconnect spark plug and fuse. But this time this doesn't works.
There was water in the box which contains filter , which I removed the water and checked everything.
Self start, horn, indicator nothing is working. Battery is fully charged. The alarm which is directly connected with battery is working.
Please Help.
