Gearbox fine when cold. After about 25 mile drive it sticks in some gears, revs up between changing gear. Got oil changed. No difference. 2007 model. 79,000 miles. Can anyone help? Thanks.
Have you checked if the fluid is at the correct level? Has it been changed recently? – Timo Geusch Apr 4 '12 at 20:17
hi i have the same problem..... love to hear if you got it sorted.. its very annoying. done same as you got gear oil changed and still happening – user1788 May 10 '12 at 14:11
@Stephen Actually everyone would love to hear if you were able to resolve this. If you did, post it as an answer please. – Tim May 10 '12 at 16:30
I have been having a similar problem especially when decelerating to islands and then accelerating away, the gear box has hesitated and not changed down before accelerating.
I have only done 36,000 miles, so I don't beleive it is the gearbox at all I beleive its the ECU not getting the right torque settings for a particular shift pattern. Last week stopped off at local post office to pick up a parcel and when restarting the car the engine light came on and in limp mode fopr 10 minutes. I stopped the car and restarted and all appeared ok but for the engine light which stayed on for 2 days.
After the initial problem the car has totally changed its driving performance, no hesitation or sticking in gears at all, turbo like acceleration throughout rev range and almost inpercetable changes.
I believe its either a small air leak in the boost line at the front of the engine, a dirty EGR valve or a clogged boost valve near the EGR. Try cleaning with carb cleaner before any drastic gearbox action.
Assuming that you've checked that the oil was of the correct specifications, and that it's at the correct level, there are three main options.
  1. Gearbox rebuild
  2. Gearbox replacement (new or used)
  3. Drive until it breaks (which might be never)
