A transmission mechanic gave me the following error codes for my Kia Sedona 2005 model. Not sure what they mean and which ones I need to have fixed.
- P2422
- P0116
- P0304
- P02015
Any help or suggestions would be greatly appreciated. Thanks
Any help or suggestions would be greatly appreciated. Thanks |
From troublecodes.net: P0116: Engine Coolant Temperature Circuit Range/Performance Problem P0304: Cylinder 4 Misfire Detected The other two are not listed here. Check your coolant, clear out the codes and see if any show up again. If they do, then it's time to get the car into a mechanic. |
