Tell me more ×
I have a 2001 Dodge Durango, and the passenger-side brake light will not work, even after replacing the bulb.
The bulb that I replaced was obviously burned out. I double-checked the new bulb, and it looks fine. I checked the connectors on the inside of the bulb housing, and it looks fine as well--very clean. I thought about a fuse, but figured if it was the fuse, all the brake lights would stop working.
The tail-lights work fine, as do the signals.
Any insight?
up vote 2 down vote accepted
I finally got this figured out.
The housing inside the actual tail-light assembly had become deformed, I guess due to heat, thus keeping the light-bulb housing from making proper contact with the tail-light assembly. A new tail-light assembly fixed the issue.
Thanks, everyone, for your help with this issue.
Last time I saw that problem it ended up being the socket on the vehicle. Could also potentially be wiring of course.
Thanks for this. I'll try checking the socket/assembly with a multimeter, and see where that gets me. – Tyson Phalp Mar 16 '12 at 15:42
I would still check all your lighting fuses, sometimes your brake lights/taillights will be on separate fuses.
Fuses are fine. I also took the advise of @Brian Knoblauch, and checked the socket, and it seems to be getting power. I'm completely stumped! I even swapped the sockets that hold the bulbs, and the same thing is happening--right side doesn't work, left side does. I've swapped bulbs, and bulb sockets (the part that you twist and remove from the light housing), and the right side still doesn't work. – Tyson Phalp May 4 '12 at 17:50
