Sign up ×
My '98 Protege makes a high pitched whine for the first couple hundred yards when both the engine and outside temperature are cold (below freezing). It doesn't sound like a squealing belt. The sounds is an annoyingly high pitched metallic whine that increases in frequency (and volume) as the engine revs. I think it's one of pulleys (or bearings) on one of the accessories, water pump, or the A/C compressor, but I can't figure out which one when looking under the hood. I suppose it could also be one of the belt tensioners or idler pulleys. So, the question is this: how can I figure out which one is the culprit?
up vote 5 down vote accepted
Rubber tubing is a cheap alternative to a stethoscope. You can buy a couple feet of it for a couple dollars at any hardware store, just be careful where you point it.
Thank Click & Clack for that, it worked for me.
+1 This should work almost as well as a automotive stethoscope, except it won't block ambient noise quite as well. – S_Niles Mar 15 '11 at 6:13
Use an auto repair stethescope or even a long socket extension as a substitute to listen to each pulley when you start the car.
If it's truly a bearing issue you'll hear it right away when you find the affected part.
Re: the socket extension trick: I take it you mean aiming the extension at the suspected part and holding your ear up to one end? Might be worth clarifying. – William Cline Mar 14 '11 at 16:02
Yes, but you want to make contact with a stationary area of the pulley (usually the fastening bolt) to listen to the bearing noise. – kkeilman Mar 14 '11 at 18:19
