Take the 2-minute tour ×
I have heard a few different ways to fix a pin hole leak in a radiator. I have heard put a small amount of black pepper in the radiator, or use jb weld to patch the hole, and not to use the stop leak antifreeze.
Any suggestions?
add comment
3 Answers 3
up vote 5 down vote accepted
If you are willing to drain the coolant, most radiators can be brazed or welded to fix pinholes.
does this include aluminum radiators? –  BrettAdamsGA Jan 24 '12 at 16:27
Aluminum radiators can be welded by someone who knows what's they're doing. –  Timo Geusch Jan 25 '12 at 0:28
add comment
If I didn't really care if I might hurt the car, I might be willing to try JB Weld...
Seconded. At worst you'll ruin an already-dead radiator, not any other part of the car. I've had luck with this method in the past, although it was a giant gaping hole and I added some radiator stop-leak too after using the JB weld. –  R.. Jan 25 '12 at 5:18
add comment
I've fixed radiators in the past, but unless your car is one where the replacement radiator is really expensive, you're probably better off just replacing it. A new radiator will usually give much better cooling performance. Last time I replaced a radiator is was just $70 or so...
add comment
