The key wont turn in ignition switch, I can't change the gear (the button is locked sort of). 2000 Plymouth Neon Automatic. Is there a temporary fix to it? Never had this problem before.
Tell me more
Motor Vehicle Maintenance & Repair Stack Exchange is a question and answer site for
mechanics and DIY enthusiast owners of cars, trucks, and motorcycles. It's 100% free, no registration required.
Can you turn the steering wheel? It can be in a lock position. If so, then turn slightly the steering wheel and retry your key. |
This could be cold related I have to leave the car at work because I could not turn the key. The next day tried in the morning, but to no avail. Then came in lunch break, made another effort and after a little this and that, the key finally turned. I am thinking this could be cold related. The temperature has been very cold here (10F-1F). All drinks in the including cokes had frozen and one of them had bursted with the Can ripped. In the noon, while it was still cold, it was a little bit better and I think that made the difference. |
