I have a 2002 Skoda Octavia. Recently I've noticed that when it's cold, the gearbox is very recalcitrant, particularly in the lower gears. The feeling is of "stodginess" with a slight audible squeak.
Does this mean the gearbox oil needs refreshing? Is this easy to do at home? In the Hayne's manual, it suggest that to do this you need to jack the car up at both the front and the back, so that it is completely level. I'd have to get extra tools to do that right?
Is there anything else that could cause this (worn linkages/bushes?)?
