I'm searching for a throttling valve that uses oil in order to convert pressure into thermal energy that can then be extracted via a cooler. Is there such a thing as a oil throttling valve? It would also need to handle fairly large pressures (1000 - 3000 psi). The whole idea is to dissipate approximately 400 kW of power during the most extreme situation. Does anyone know of a better way to convert kinetic energy (spinning shaft) into thermal energy for extraction? Btw this is a fairly large vehicle (about the size of a dump truck)
Thanks, Digimas
I think you need to give more information about the application to attract answers.
For example, define "dissipate": do you mean to scrub off enough thermal energy to bring temps to within 2 degrees of ambient? 20? 200?
Is the goal to use this intermittently or for constant use? Big difference in BTU's there.
And is your goal to bring the shaft to 0 rpm or simply to apply a load of up to 400kW to a shaft powered at a much higher level? Do you have a time constraint for reaching desired shaft speed? How much hysteresis is allowable? etc.
Hope this helps...
