My 2000 2.0L Golf GLS won't blow hot air at operating temperature, the air is only lukewarm at best. This started a few months ago inexplicably. The car isn't overheating or underheating, it reaches operating temperature in the same amount of time as before. Here's what I've done:
  • Checked coolant level - there's plenty.
  • Flushed coolant system - the previous owner mentioned this same problem and a flush solved it for him, no such luck for me. Ran some Prestone Flush, then flushed water twice, then refilled with regular Prestone (not G12, I know). The only thing that worries me here is that I never felt like I was able to drain all of the fluid when flushing (always found: amount in > amount out).
  • Bled coolant system - elevated the passenger side (where the bottle is) by driving up onto a snow bank, let it run for 3 minutes. Coolant level didn't change.
  • Tested thermostat - works correctly and opens right about 195 F. Note that on this vehicle the thermostat blocks off the radiator loop, not the heater core loop which is separate and not controlled by a thermostat.
  • Checked for heater core blockage - using the input and output connections at the firewall I was able to pass fluid through the core using both gravity and light pressure. Flow rate was substantial, don't suspect blockage.
  • Checked water pump flow rate - using a clear hose I bypassed the heater core altogether and ran coolant from the engine block output straight back to the coolant bottle. At idle the pump wasn't able to overcome gravity to push up and into the bottle, but as soon as the engine rev'd coolant pumped quickly and with ease.
  • Checked water pump - OEM VW pumps use a plastic impeller and I suspected it had broken. Pulled the pump and found it was already the metal impeller kind; turns out the previous owner replaced it 2 years ago. Put the old one back in, it's still good.
My car doesn't have Climatronic, just the standard climate control system; does that mean it's cable or vacuum controlled? At this point I'm wondering if there isn't simply a fan control gate that's stuck or something. Even though I was able to pass water through it, are there any gates or controls within the heater core itself?
Replacing the heater core is a 8-16 hour DIY job or $850 down at the shop, and I'm not prepared to do either. Short of actually looking at the core, is there anything else I can try, check, or do?
Thanks all, I've been wracking my brain with this one and would love input!
UPDATE:
After trying my best not to I decided to replace the core. I used a very helpful VWVortex guide along with a Chilton's manual. 14 hours later I've got air that measures significantly hotter than before, so now it's time to wait and see how things go this winter. I found that I don't have a split HVAC box even though I don't have the Climatronic system (major letdown) and that the flappy bits inside the box were in great shape and moved freely. The old heater core was definitely clogged; simply trying to blow air through it was difficult. For your enjoyment here's what the car looked like when I was finally able to remove the core:
2000 VW Golf dash guts
+1 for a great problem summary – Bob Cross Jan 7 '12 at 1:31
I think you should get +1000 reputation for simply attempting this job. Now tell us, how many new rattles from inside the dash? – mac Sep 3 '13 at 19:17
@mac: Thanks! It's hard to tell which noises are new (there are so many to choose from...) but things buttoned back up nicely with only a small handful of orphaned screws. – Mr. Buster Sep 3 '13 at 19:41
mine is also bypassed cause of the same problem I need to fix it before winter – user9180 Jan 22 '15 at 13:50
up vote 4 down vote accepted
It looks an awful lot like you have diagnosed all of the really hard problems and come up negative. I wonder if you have a simple mechanical problem: is the linkage sound between the hot / cold selector and the flapper valve that forces air past the heater core. From what I hear, the foam around the flapper is also prone to disintegration in humid climates: that would allow all or most of your heated air to escape.
EDIT: I did manage to find a reasonable annotated heater core replacement. I think you're right: this job is a huge pain. And, no, I can't think of a way to get at the internal air direction valves.
Yet another EDIT: Thinking about the diagnosis further, it occurs that you might be able to establish whether you have a bad seal on the flapper valve. This will work best on a very cold day.
  1. Run the car up to operating temperature with heater set to coldest and vent fan off.
  2. Set the vent fan to the least speed that will blow detectable airflow. This will ensure that you're not feeling artificially cold from the wooshing air from max vent fan.
  3. Check this baseline temperature as best you can: if you don't have a good thermometer, I find that a sniff test works for me. Seriously, the inside of your nose and sinuses are very sensitive to temperature. That's how I've detemined what coats and hats my kids needed to wear to school for years.
  4. Set the heater to max (this is where you'll hear the clunk of that valve flapping over).
  5. Wait for what heat is available to make it's way down the vent (i.e., a few minutes).
  6. Check the temperature again. If you have a working valve with a bad seal, you'll note a slight temperature change (see previous note on sniff test).
Now, even with all of the above, fixing any of these problems will be approximately the same level of hassle. You're going to have to take off the dash, etc. My hope is that, if you do invest the time, you'll know what you're looking for. I'm pretty sure that this isn't a job that you're going to want to do twice.
I haven't had a chance to check that linkage, no. Swinging the selector between hot and cold makes a 'thunk' sound, as it had before, if that means anything. As I understand it the flapper is part of the core assembly and buried deep in the dash - manual inspection might not be feasible. Do you have any suggestions on how to check it? I'll see about pulling the climate knobs out of the dash to inspect that end of things. – Mr. Buster Jan 7 '12 at 2:17
@Mr.Buster, I updated the answer, trying to think about how you could diagnose things further. – Bob Cross Jan 9 '12 at 12:38
thanks for these edits and your help! I've ran across several more issues that are taking precedent over this one (a failed window regulator for one - when it rains it pours) so I'll have to check out the flapper valve later. – Mr. Buster Jan 13 '12 at 23:18
@Mr.Buster, you're welcome. Good luck! – Bob Cross Jan 17 '12 at 14:03
Had similar issue in Skoda Felicia (which is much like an older Golf) I own. Check these steps:
  1. Close the salon heater. Start the car, wait till coolant gets to its normal temperature.
  2. Now open salon heater to the max and check if it readily blows hot air. The air will be hot at first, but quickly loose temperature.
  3. Close the salon heater, wait ~5-7min and repeat step 2, it should act the same.
In such a case that is a broken wall inside salon heater core, so instead of going through the core the coolant was just short-circuited to out. Had to replace the heater core and all went back to normal.
You could check the temperature of the hoses going to and from the heater core from the engine side of the firewall when the vehicle is warm and with the heater on. If both hoses are warm, then you are getting coolant flow through the heater core and your problem is likely inside the vehicle with the air control flaps, possibly the foam seal has come loose and is blocking the warm air flow. If only one hose is warm, then you aren't getting much coolant flow through the heater core and your problem probably lies in the engine compartment. Some vehicles have a vacuum operated valve the turns off the water flow when the heater isn't required, the valve might be stuck, it would be installed in of the heater hoses under the hood.
If VW are anything like a BMW, there should be a valve that allows for hot coolant to flow through the heater. If this valve fails, you get no flow and the air never heats up. The valves are electric on BMWs, so looks for a valve that has your heater hoses going through it and check for operation.
its the plastic peice the cable connects to. the small peice that screws to the laver breaks the clips and falls out of socket with the temp. flap arm.
Can you be more specific? Which cable and which plastic piece? – Mr. Buster Mar 23 '12 at 17:54
