I have a 1998 Ford Contour that has a check engine light. I checked the codes, and found:
  • P0171 System Too Lean (Bank 1)
  • P0174 System Too Lean (Bank 2)
  • P0401 Insufficient EGR Flow
  • P1131 Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1
I think the main culprit might be a vacuum leak, and that the codes are related to the side effects caused by the leak. Are there any common hoses that I should check first? I remember we had two main hoses on BMWs that were usually the guilty party.
Checked for leaks, and found none. I did find that the fuel pump might not be coming on. – FossilizedCarlos Dec 23 '11 at 15:01
Check the ground on the fuel pump wiring, it's easy to get to, pull the rear seat. If it looks corroded, clean it off. – Mark Johnson Dec 23 '11 at 17:28
I'm guessing since it was throwing a code for EGR flow the engine was a 2.5L Duratec? The '98 2.0L Zetec has VVT instead of EGR. – Mark Johnson Jun 21 '12 at 21:10
up vote 2 down vote accepted
The problem did end up being the fuel pump. Checked wires and fuses, but in the end it was a bad pump. The filter was also replaced, and can probably be blamed for the pump failing.
