Trucks use yellow and red coded ISO 1728 "palm couplings" for connecting the air supply and braking compressed air lines from the towing vehicle to a trailer.
I want to build an adapter from the compressed air supply palm coupling (red lid) to a European standard compressed air coupling (7.2 mm nominal inner diameter). This is to power a tire filler or compressed air tools with the truck when I need this on the go.
I'm not sure about which parts will fit together (thread size etc.). Suggestions?
