This is a very common problem with Dodge Neon cars. They flood in the back seats big time. I had this problem with 1998 Dode Neon (manual), then bough 2000 Neon. Inititially it did not flood at all but now it does. I searched the forms, could not find a solution anywhere. Does anyone know why Neons flood with water in rain?
Is it Convertible? Sun-Roof? The more specific you are, the better the answer. – FossilizedCarlos Nov 20 '11 at 1:56
I have never seen a convertable dogde neon. No it is not. To clarify more, everything else in the car is dry, windows, mirrors, seats, consoles, dashboard, everythingg but there is pile of water in the rear back. I believe it is more of those recall problems but they never addressed it. – Dave Nov 20 '11 at 14:08
Do you have any sort of roof antenna? Or if not centralized, can the windows be leaking? – FossilizedCarlos Nov 20 '11 at 19:04
NOT AT ALL. Everything else is dry just the floors and there is pool of water in car! Obviosly if there is so much water (not just wet), this must be a design fault when everything else is dry. – Dave Nov 22 '11 at 12:16
Yeah, that's just weird. Have you called anyone to see if maybe there is a recall for this? Sometimes they put bulletins out, they are not actual recalls, but they work the same. – FossilizedCarlos Nov 23 '11 at 6:21
I wish you luck. In my experience any car that's 10 years old or more is probably leaking somewhere, just most times people haven't noticed yet (although, they eventually notice when the floor rusts through and falls out). The causes of leaks are multitude. You just have to go around every spot where there's a break in the metal (antennas, windows, trim, handles, gas doors, etc.) and inspect carefully/hose down while watching for water...
This problem is abudant with Neons. My 2000 is in very good condition and clean. The only way I can see what is underneath is take all the carpet out but I dont' suspect anything wrong there. To me it does look like a design flaw that shows up when the car gets older. The most prominent suspect is underneath the mat but then I wonder how. No one even sits in the back that it would get damaged. – Dave Nov 22 '11 at 0:20
I really doubt anything from underneath is soaking your rear seats and/or floor in such a way that you would notice unless you are fording rivers in a neon. Prime suspects in this order. rear window seal, trunk seal, rear door seals. – Rig Nov 25 '11 at 14:23
