Sign up ×
When dealing with a car with aluminum head(s), what is the proper way to extract a broken sparkplug?
Can you be a little more specific? The ceramic stem is broken, or the "nut" portion is broken as well, leaving only the threaded portion in the hole? – S_Niles Mar 9 '11 at 17:41
The hole is about 6in deep and only a pices of thread is in the spark plug hole. I need a socket for an extractor do you know where I can find one? – user2907 Mar 18 '13 at 23:50
4 Answers 4
A couple ways to go about this, depending on the exact situation:
If the ceramic stem is broken, and you can still fit a deep socket on it, go with that. If the nut itself is stripped so much that you can't get a socket or an open-end wrench on it, or if the nut is broken, you should try using pliers to remove the spark plug. You could also try something like a deep socket Craftsman Bolt-Out bolt remover if it is stripped. Another option would be to drill a hole in from the top, going straight down, and using a screw extractor to remove it.
Pictures to help: Craftsman Bolt Out:
Screw extractor:
Do you want to say anything about penetrating oil? – Jay Bazuzi Mar 10 '11 at 3:00
@Jay: That should be an answer, not a comment. – endolith Jun 14 '11 at 1:14
The screw extractor would be digging into the metal of the plug? Not the ceramic? – endolith Jun 14 '11 at 1:15
Thank you so much for the info, the screw extractor worked like a charm. I spent 3 hours freaking out, 1 hour to find and buy one and literally 2 minutes to remove the broken screw part of the spark plug. It worked! – user9868 Mar 22 at 17:22
Before doing anything else, get some penetrating oil. Reducing friction in the threads will dramatically reduce the amount of twisting force required to remove the stuck plug, making the job way easier & reducing the chance of making things worse (i.e. breaking off a screw extractor!)
Follow the instructions on the container, or just spray around the threads, and let it sit. Tapping with a screwdriver or wrench will help it penetrate and break up oxidation.
One more option:
If you tried taking the spark plug out of a hot/warm engine and the plug broke off between the lug-flats and the lug-threads (both non-technical terms), you may be able to use a screw driver or chisel to gently tap the remaining portion out.
Here's why:
  • When your engine is hot, the spark plug holes are compressed due to the expansion in the metal making a much tighter seal. When the engine is cooled, the engine head metal contracts to its natural position, so the plug threads will not be stuck in the threads.
  • All of the tension holding a plug into the head of your engine is held by the lip of metal around the lug-flats when it is compressed by tightening the plug into the head. If the plug snapped between the lug-flats and the lug-threads, there is no longer a lip holding compression on the spark plug. In other words, it is just sitting in there with little to no resistance keeping it from turning out. A screwdriver or chisel tip can be pressed against one of the jagged edges and used to turn the remaining spark plug back out.
Take a careful look at this special situation before you go the extractor route. An extractor in inexperienced hands can ruin a head.
I'm sorry I don't have pictures.
One other tip that you may wish to try if there is no way to get a socket on it, two long screw drivers down the inside of the remains of the plug so they nip up against the electrode tip and try turning it out that way. I've personally had success in this scenario using this technique on a Renault.
protected by Community Jun 24 at 1:35
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site.
