I'm thinking that this is the sway bar or sway bar links. Does this sound right? This happens often and it doesn't matter which way I turn.
Tell me more
Motor Vehicle Maintenance & Repair Stack Exchange is a question and answer site for
mechanics and DIY enthusiast owners of cars, trucks, and motorcycles. It's 100% free, no registration required.
Based on my experience, I'd suspect the strut bearing plates if it has struts in the front (I'm not familiar with that particular model)... Those plates usually last about 5-10 years, then start falling apart. Makes snapping/banging/sometimes even grinding noises when turning. Eventually the steering will start to bind up and popping noises will start. |
