I have several developing rust spots on my car.
What's the best way to remove the rust / prep the surface?
I picked up a wire cup brush with a 1/4", but it's limited to 4,500 RPM. My tool options are a 1/8" collet Dremel (won't fit), 1/4" die grinder (20,000+ RPM), and a battery drill (600 RPM, and under-performing when I tried it).
  • Can I limit the die grinder's speed by limiting the air pressure and still have it be usable?
  • Do I just need to go buy something else entirely?
What should I do for the best chance at a good paint application?
I already have a can of color-matched paint in a rattle can.
  • Must I apply primer first? How many coats?
  • Is there a particular kind / concern about applying it?
  • Not relevant to this particular job, but is there a difference in the primer I'd use for metal vs. plastic?
up vote 2 down vote accepted
A wire brush is the best option for removing surface rust, but I wouldn't try the brush you have in any of the tools you've got!
In terms of painting, you can just use normal primer, but I would go for a rust inhibiting one (e.g. those sold by Bilt Hamber, Hammerite and others) - If it has started rusting there, there is a reason for it (usually stonechips), so you might as well try and prevent it reoccurring. The particular primer should tell you how many coats to use, but I normally go for around three thin ones.
Metal primers are different to plastic ones, as they often incorporate a slight acid to bond better with the surface.
In addition to all the points made by @NickC - unless you have a huge expanse of rust, a handheld wire brush might be better than anything else.
I usually keep my cars for a very long time, and this being Scotland - they rust. A lot! So I just keep on top of the sills, arches etc with wire brushes - use them at the first sign of rust and expose the metal back a good inch all round the rust spot; prime it up and respray.
Always worth keeping an old tin of your car paint to help get matching colour next time.
what is it about Scotland that makes cars rust ? humidity ? – amphibient Mar 19 '15 at 21:31
It rains here. Frequently. It's also a very small country surrounded by the sea, so there's also a lot of salt in the air. – Rory Alsop Mar 19 '15 at 21:33
oh, i see. sort of like Florida – amphibient Mar 19 '15 at 21:43
Hmmm - I would have classed it as entirely unlike Florida, actually. If you look on a map you can see why - latitude, prevailing westerlies etc – Rory Alsop Mar 19 '15 at 22:02
i meant that vehicles in FL are subject to similar environmental exposure and effects... – amphibient Mar 19 '15 at 22:03
