Take the 2-minute tour ×
My 2004 Ford Focus makes small grinding and vibrating noises when turning to the right. The problem was much more severe earlier this month. I took it to the shop and had them get me new tires and an alignment. That fixed the majority of the problems. However, i am still having the grinding and vibrating noises when turning to the right. The mechanic drove it around and said that it was probably the transmission.
I was wondering if that sounds like transmission to all of you and how much would it cost to repair or replace my 5 speed manual transmission. It has around 115k miles.
Thanks for the help!
What does it sound like? Is it a scraping sound or something else? Does it vary with the steering wheel, the speed of your turn, or what gear you're in? I wonder if this is related to the question I just posted. –  kojiro Nov 7 '11 at 3:15
It seems worse in lower gears. First and Second. But that could possibly be due to the fact that i only make tight turns at those low speeds anyways. It is a grinding noise. Sounds fairly similar to the problem you are experiencing. –  prolink007 Nov 7 '11 at 16:47
add comment
Grumbling noises while turning are usually CV joints. There are 4 of these (one each end of each drive shaft), but he usual culprit is the outer one on the side that is causing the noise - i.e. in this case the right hand one.
To check, jack the front of the car up and support on axle stands. grip the drive shaft firmly in one hand (wear gloves...), and the wheel in the other, and try to twist them in opposite directions - if it has gone you should be able to feel a slight clunky movement in the joint, although you won't be able to see it as it will be covered by a rubber gaiter.
Replacing is a relatively easy job for a competent home mechanic, or a few hours for a shop. Much cheaper than replacing the entire gearbox!
add comment
I agree with Nick. My 2000 Taurus had similar symptoms and it was the CV joint.
What all did you do to get it fixed? And how much did it cost, roughly? –  prolink007 Nov 9 '11 at 14:06
add comment
