Take the 2-minute tour ×
my 2001 honda civic is giving me problem:
When starting from cold in the morning, the car starts at one click but when driven for a while with the engine at temperature, if I stop and turn off the ignition when I try to start it again it takes a very long time to start.
When it does start and I drive for a while the car shuts off and the check light come on. I have to leave it for about 5mims for it to start again.
Can you tell us what check light is on? –  Rory Alsop Oct 6 '11 at 9:11
If the check engine light is coming on, get someone with a code reader to read the fault code and tell you what the code means. –  Timo Geusch Oct 6 '11 at 14:20
This sounds like the problem that old Chevys have. –  Jaime Oct 6 '11 at 16:11
As Timo Geusch pointed out, have it scanned by OBDII scanner. Many auto stores like autozone, o'reilly, etc, do it free. The culprit could be in ignition or fuel injection system. –  RainDoctor Jul 17 '12 at 20:59
You can also pick up one for under $20 on Amazon: amazon.com/Autel-MaxiScan-MS300-Diagnostic-Vehicles/dp/…. Don't get ripped off paying $60-200 for one at an auto parts store. But like others have said, if you just want one scan, stores will usually do it for you for free. –  R.. Jun 10 '13 at 14:50
4 Answers 4
On a first generation Acura Legend (a Honda), this problem is almost always caused by the main relay being old / stuck. You can smack it (located by the fuse panel on the dash), and it'll start.
The symptoms you described have 3 common causes on Honda/Acura vehicles.
First: the "shoulda" disclaimer Reporting the code that drives that check engine light you saw is the most important piece of information you could give us. Without that code everything is blind diagnosis (guesswork) based on a myriad of personal experiences. This is the most inefficient way for you to get your answers. Before attempting to replace parts or diagnose via this thread please go retrieve the code, many parts stores will check it for free.
Common Causes of your symptom
  1. Main Relay - The main relay has a responsibility for delivering power to your fuel pump. If you turn the key into the run position without cranking the car you should hear a buzzing sound from the rear of the car as the fuel pump runs until a programmed pressure threshold for the fuel system is achieved. If you hear the fuel pump and the car starts then this is probably not the problem. This part's failure does not typically cause a check engine light.
  2. Ignition Module - The ignition module is a compact device located in the engine compartment . Sometimes the manufacturer's construction of this device will allow internal solder points to become brittle and open circuits can occur most commonly when a vehicle is warmed up or external temperatures are extremely hot. Typically the beginning sign of a failing ignition module (igniter) is hard start problems when the car is hot. Eventually it will completely fail. This module's failure will cause a check engine light.
  3. Bad Grounds/Connections - This is the most uncommon and most difficult problem source to solve since it involves referencing several logical paths of operation and testing those paths .
That's about all I have from common issues I've encountered for the problem you have reported. The injector leak down response has slight credibility based on some reading I've done, though I've never seen injector leakdown keep a Honda from starting.
When you get into the car, turn the key to on position but do not start the car. While everything is quite, do you hear whirling sound. If you do, that's your fuel pump creating fuel pressure. If you do not hear the pump making the noise, then as up_the_irons pointed out, it could be the relay (@up, is that what you meant by "main relay" or do those civic's have something else?).
Another possible cause is leaky injectors. I had an 89 acura integra (i.e. rebadged honda) and it had both bad relay and bad injectors. Relay was easy to identify. Injectors took me a little while.
But symptoms were kinda what you describe. If the car sits overnight, it would start fine. If I just drove it, it would start fine. But if I left it sitting for few hours it was very hard to start it. Explanation I eventually came across was that injectors leak while engine is off because fuel lines are still pressurized. If you just drove, they haven't leaked enough to flood cylinders. If the car sits for a long time, the gas will drip out past the compression rings into your oil. But at just the right time interval, you end up with flooded cylinders and a car that's really hard to start.
I went to a junk yard, bought another set of injectors, shipped them out to be professionally cleaned/calibrated, then swapped them in and never had tough start problem ever again.
Are you sure that the fuel pump should be running with the key on, but engine stopped? I'm not familiar with Hondas, but all the other modern cars that I am familiar with, the fuel pump doesn't run unless the crank angle sensor detects that the engine is turning. –  Brian Knoblauch Oct 19 '11 at 12:20
@brian I disagree a lot if not most cars turn on the fuel pump for a few seconds to prime the line so to speak when the ignition switch is first turned on. The fuel pump stays on based on some other metric like oil pressure or crank angle sensor –  Move more comments link to top Oct 22 '11 at 15:08
Your problem is the coolant temperature sensor. Try unplugging it and if it will start without it the sensor is damaged.
Bad ECT sensors can cause non-starting issues. See honda-tech.com for a conversation about ECT sensors.
...yes a bad ECT can cause hard starting or a no start condition.
If the ECT sensor is bad you can get a new one for around $30.
It maybe a workaround to get it started, but it does nothing to address the cause of the problem or fix it. Recommend for deletion. –  theUg Jun 17 '13 at 15:31
This does not provide an answer to the question. To critique or request clarification from an author, leave a comment below their post - you can always comment on your own posts, and once you have sufficient reputation you will be able to comment on any post. –  theUg Jun 17 '13 at 15:31
