I would like to know the technical name in english of the box/container/cabinet (that external square case, but not the reservoir where the air is compressed) of an air compressor.
Tell me more
Motor Vehicle Maintenance & Repair Stack Exchange is a question and answer site for
mechanics and DIY enthusiast owners of cars, trucks, and motorcycles. It's 100% free, no registration required.
closed as off topic by Brian Knoblauch, Larry♦ Sep 28 '11 at 21:40
Questions on Motor Vehicle Maintenance & Repair Stack Exchange are expected to relate to motor vehicle maintenance and repair within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
That (in the HVAC industry) is simply called the compressor. |
I suspect there is no official technical term for the component you desribe, it would simply be described as the 'casing' or 'cover' for the compressor itself. Most compressors I've come across are uncased, with the motor and compressor unit mounted on top the reservoir. |
