My Ford Focus had an evaporator core leak, so the DIY hobbyist in me took apart the instrument panel, dashboard and finally, replaced the evaporator core. I'm on my way putting parts back together. I've more or less put together the dash and instrument panel and the only part that's left undone is the gearshift (yes I took the gear shift out in the process :(
Now I'm faced with a dilemma, I have a mystery wiring harness underneath the gearshift( please see the picture attached). The big arrow shows where the harness for the gearshift should go (to the male connector behind the gear shift). The arrow with a question mark is pointing to the mystery harness which I don't know where to plug into. I've looked very carefully underneath the gearshift, but did not find a matching male connector. I know that harness as the Traction Control Switch Wiring Harness. This is as far as I went, I have no idea where this female Traction Control Switch Wiring Harness should go. I'd really appreciate it if someone can drop me a hint. Thank you very much for your help!
