I have Toyota Camry 2000. The problem is AC does not blow any cold air. So, I bought R134a and recharging it myself. It costs me about $12. However, it lasts for about a month.
I checked with couple garages near by. Cost for checking AC is vary from $60 to $150. They told me it covers only investigating NOT fixing cost.
So, the question come up to my mind is: Can I keep charging R134a without getting it to repair? Will it have serious damage to my car? Is it good thing or bad thing?
up vote 8 down vote accepted
I assume that when you mentioned that the recharge only lasted for a month, that was until the a/c stopped working again? Usually a/c stops working when there is not enough pressure in the system due to it being low on refrigerant and given how long a non-leaking system normally lasts without a recharge, you've got a fairly substantial leak in a/c terms.
You can probably get away with a couple more recharges but keep in mind that the refrigerant also includes the lubricating oil for the system and if you keep topping up the refrigerant, the ratio might be off, which can do further damage to the a/c system and your wallet.
I would consult the local yellow pages for an automotive a/c guy - a lot of garages (especially the smaller ones) don't have the gear and licenses to deal with a/c anyway so they often farm it out to a mobile guy. Getting said mobile person to come out and check out your car's a/c will at least save you the overhead the garage charges on top of what the a/c person charges.
Also, the reason that they're only quoting you for the diagnostics is that in order to find a leak, some refrigerant will have to be replaced by a UV dye, then you get to run your car for a few days with the a/c on before the actual leak check can be done. Only at this point it's even possible to figure out what needs replacing as it can be anything from the compressor to a line to the evaporator or receiver/dryer. And without knowing where it leaks you can't diagnose the problem in the first place.
Refrigerant is key to keeping compressor safe. Good answer. Any repair that includes compressor repair becomes expensive very fast. – FossilizedCarlos Sep 12 '11 at 1:35
Get a used compressor on Ebay for $25. Slap it in and add some refrigerant. You're done. Garage quoted me $800 for just the labor. Nonsense.
Can you edit your answer to expand on it ? Also, you could align it a little better to the question being asked! :) What makes you think that the compressor has gone bad? – chilljeet May 6 '15 at 5:12
