After months of normal driving with no problems, my 2003 Honda Civic EX check engine light came on during a long trip. Got it scanned and it's P0420: Catalyst efficiency below threshold bank 1. They said it could be a bad catalytic converter or oxygen sensor.
I borrowed a scanner and tried to measure the oxygen sensor readings over time. Doesn't seem to have good time resolution:
This is voltage vs "time", though I don't know what units "time" is in, or if this is useful in any way. The code did not occur during this graph, anyway. Apparently the sensors are supposed to switch on and off like this?
The lambda sensor's output voltage should not remain constant, however. It should flip-flop back and forth from rich to lean as the PCM increases and then decreases the amount of petrol injected into the intake manifold. Every time the voltage reverses itself and goes from high to low or vice versa, it's called a "cross count." A good O2 sensor on an injection system should fluctuate from rich to lean about 1 per second. If the number of cross counts is lower than this, it tells you the O2 sensor is getting sluggish and needs to be replaced. http://www.fordscorpio.co.uk/obd2scan2.htm
Though another site says:
Once a fully functional catalyst is up to working temperature and is “lit”, we should see a nice “flat line” signal from the downstream sensor, which shows that the exhaust gases have been successfully converted. http://www.picoauto.com/tutorials/cat-efficiency.html
An example of a single frame:
MIL STATUS       OFF
ABSLT TPS %     25.4
ENG SPEED RPM   3018
CALC LOAD %     74.9
MAP KPA           75
COOLANT °F       194
IAT °F           109
IGN ADVANCE DE  21.0
ST FTRM1 %       0.8
LT FTRM1 %       3.9
VEH SPEED MPH     20
FUEL SYS 1      CLSD
FUEL SYS 2       N/A
O2S11 V        0.875
ST FTRM11 %      3.1
O2S12 V        0.780
ST FTRM12 %     -1.0
OBD2 STAT         CA
Frame    21
Time    74.3
I cleared the code and it didn't come back during normal driving, but then during the long trip in the opposite direction, the engine light came on again. Both times the light came on were shortly after filling the tank and getting back on the highway. (I measured 38 mpg during this trip, which doesn't sound like anything is seriously wrong with efficiency.) I assume it's the same code this time but haven't read it yet.
It passed emissions inspection 02/19/2011.
I have oscilloscopes and volt meters if that would help figure out the cause.
Update: I replaced the upstream oxygen sensor and the light still comes on. It comes on after filling the tank with gas, and goes off after filling the tank with gas. So something about the gas being slightly different from one station to the next?
Update: Mechanic replaced the catalytic converter at the usual high cost, and the light still comes on occasionally.
I swear it comes on every time I'm behind another car/truck that has a smelly exhaust, then goes out a few hours later.
Apparently this code could also be caused by a cracked exhaust manifold, which is a common problem with these cars?
Yep, most likely a bad O2 sensor and/or bad cat. – Brian Knoblauch Sep 8 '11 at 12:44
@BrianKnoblauch: Yeah, but which? An O2 sensor is $$, while a cat is $$$. – endolith Sep 8 '11 at 15:57
If the O2 sensor is really bad, you'd replace the rear one on bank 1. The rear/secondary sensor is the one that determines catalyst efficiency. Bank 0 vs 1 is manufacturer/model specific. You'd want to consult the manual. If the cat is bad, you'd want to find out why (oh, and it should be under warranty, I believe they're required to last 10 years nowdays). A mixture issue can lead to catalytic converter failure, and if you are forced to buy one, it'd be pretty unpleasant to just ruin that one and have to replace it again! – Brian Knoblauch Sep 8 '11 at 16:22
Narrowband O2 sensors (which is what you have) switch between rich and lean indications exactly as your graph shows, so they are at least partially working... You'll need to find out which sensor is which but if S12 is the secondary sensor, this graph looks a little weird to me (assuming it uses the high voltage as a 'rich' indicator, which is what I'm used to seeing) as the second sensor seems to be staying 'rich' a little longer than I'd expect. Nevertheless it's hard to tell from the graph if it's the cat or sensor. I'd get the sensor checked out first, though... – Timo Geusch Sep 9 '11 at 14:36
hey what cat did you replace?? the one in front of the motor? or the one in the back of the motor? i have a 2003 accord v6 ex model mine has two cats with two oxygen sensors comming right off the engine – user2528 Dec 20 '12 at 7:41
It was indeed the catalytic converter (the EX does not have a pre-cat). After replacing it, the downstream sensor graph spends most of its time above 0.5 V, as it should if the converter is working.
Update:
I started getting this error code again, a little over a year after replacing the cat.
I also finally found a guide on how to read these graphs, from a reliable source: Acura ServiceNews: Diagnosing Catalytic Converter DTCs
You should see these voltage readings from the oxygen sensors on a healthy converter:
  • Cruising speed, steady throttle: About 0.6 to 0.8 volts at HO₂S Sensor 2 (the heated oxygen sensor downstream of the catalytic converter).
  • During deceleration or fuel cut: 0 volts at HO₂S Sensor 1 (the heated oxygen sensor upstream of the catalytic converter), and 0 volts at the HO₂S Sensor 2. (The 0 voltage is due to no combustion and lots of oxygen in the exhaust.)
  • Throttle opening after deceleration: A gradual rise to 0.8 volts at HO₂S Sensor 2.
Update:
It came on again constantly. Another pending code popped up for a misfire. We replaced the spark plugs which were dirty-looking, and did a compression check and changed the oil. The lights all went out and haven't come back on, and it starts much more easily. So it looks like it's just an old car and the rings are leaking a bit and burning oil and getting the spark plugs cruddy and that's why the P0420 comes on?
Update:
It came back on again. ಠ_ಠ
I just got the same code in my '02 Corolla (which burns oil, as is common for this generation). It seems commonplace that the cat's lifetime is shortened by the burning oil. I don't imagine spark plugs will cause a P0420 to be thrown. It sounds like the misfire code was coincidental, IMO. – Shamtam Jan 6 '15 at 1:26
@Shamtam: Well both errors went away when I changed the spark plugs. Misfires will let unburned fuel into the cat which ruins it, right? – endolith Jan 6 '15 at 1:34
I got the same code with 2000 tundra. I found you need to compare HO₂S Sensor 2 to engine load. If engine load is low enough, the sensor voltage should be 0 for a period of time as well. When decelerating, engine load is low, rpm is low and throttle position probably is close. Not a technician, just leaning.
A common problem in Civics of that year. It's not the main catalyst that goes bad, it's the pre-cat (the one hanging right off the exhaust manifold). This one is for cold start and once your car is warmed up, the lion's share of the work is done by your main catalyst.
Take it in to the dealer to have your pre-cat checked. Many cars have a 10 year warranty on emissions equipment.
how do you know that's the problem? – endolith Sep 21 '11 at 19:32
For the record, my car is the EX, with the D17A2 engine, which only has one catalytic converter in the exhaust pipe under the vehicle, so that's not the issue. The D17A6 has two catalysts (one in the exhaust manifold and one in the exhaust pipe). The D17A1 has only the one in the exhaust manifold. – endolith Feb 8 '12 at 2:29
