Take the 2-minute tour ×
I've got horrible rust stains on my car's rims, and I'm at a loss as to how to get rid of them. A bit of googling suggests the use of steel wool, but I'm not sure how much I trust that. Any suggestions?
alt text
Looking at the photo, I'm curious if it's really rust or if it's simply brake dust. Wouldn't hurt to try some basic wheel cleaner. –  BMitch May 11 '11 at 16:37
add comment
migrated from diy.stackexchange.com Aug 30 '11 at 14:49
This question came from our site for contractors and serious DIYers.
I'd try some CLR in a very small spot to see if it can remove it. I'm not sure the effect it will have on metal so try it in a very small/inconspicuous spot first (maybe on the very edge of one of the spokes).
Definitely try CLR. Great stuff. Always spot test anything like that first. –  woodchips Nov 26 '10 at 12:52
and as a side note .... do it somewhere well ventilated .... CLR is pretty ripe stuff ... works like a charm .... stinks to high heaven. –  Scott Vercuski Nov 26 '10 at 14:54
add comment
The photo you have added is not of Chrome rims. Chrome rims are a lot harder and can be cleaned with what you've suggested.
Aluminium rims are a lot softer and easily get stains though they don't get the actual rust(mostly).
I have similar stains on my Ford and was able to get rid of it after 2-3 iterations of Armour-All Wheel cleaner.
I think any decent off the shelf wheel cleaner should be able to help you. Though I don't believe it will be done in one go, you will need to repeat it a few times.
add comment
I've had very good results with Nevr-Dull - Magic Wadding Polish. It will take a bit more work to clean your wheels than CLR (or some other corrosive) but is probably safer for the wheels, and avoids the potential damage that steel wool might cause.
add comment
An Oxalic acid scrub is the old standard method of removing rust stains from chrome and other metal objects. It's sold as "wood bleach" in lumber yards, and likely sold as "rust remover" at hardware stores. My tin of the stuff is 20 years old, so I'm not familiar with what the brand names are today.
add comment
You could try using Cola and report back the results ... the Mythbusters didn't try Cola on Aluminum (which is what I am assuming your wheels are made of).
You should try using one of the 3M (or any other brand) recycled plastic bottle scrubbers. The aluminum should not be harmed as it is a much stronger material than thin woven plastic.
add comment
Mother's wheel polish has never failed me.
Got any recommendations on how to use it? –  Mark Johnson Oct 27 '12 at 3:08
Per the directions on the container is recommended. –  Brian Knoblauch Sep 12 '13 at 16:50
add comment
