My CBR 600 F4i idles at about 3000 rpm when the engine is cold, after about 2 to 3 minutes when the engine warms up, it settles back down to regular idle speed of about 1300 rpm.
Is this normal for this bike?
My CBR 600 F4i idles at about 3000 rpm when the engine is cold, after about 2 to 3 minutes when the engine warms up, it settles back down to regular idle speed of about 1300 rpm. Is this normal for this bike? |
Almost all engines will idle faster when cold than when warm. My fuel injected ZGR-1400 does so. My car does so. My KLR 650 and my girlfriend's Ninja 250, both carbureted, idle fast with the choke on. When your engine is cold, the fuel mixture needs to be richer in order to achieve combustion. That will cause the engine to idle faster, and that is why every engine recommends that the idle speed be set when the engine is nice and warmed up. A fast idle for a cold engine in cold weather is normal. |
It is perfectly fine. Its much better for the engine to warm up on steady 3k RPM before you start reving it to maximum. This will make sure the oil has proper density and all components are well lubricated. A friend of mine has a Fireblade and the behavior is very much the same. Until the engine gets warm its running on ~3k RPM and then drops to just a bit over 1k |
Not too sure but this looks usefull; Thought that might be the case, I suppose alternatively phone up your local garage or tuning specialist and they might be able to tell you? |
