Most of the time my 2001 Honda Civic sounds like this... Vrooooooom. But some times when I start driving it sounds like this... Vrooom putt pa putt pa putt pa vrooooom. When it's in the "putt pa putt" mode, pressing the gas makes no difference. The amount of time it spends in "putt pa putt" mode varies, sometimes its a couple seconds, other times its as long as 5-10 seconds.
This always happens within the first 100 yards after starting the car, and it runs fine after that. It is not throwing any error codes, so if it's misfiring it's not reporting it.
What would be the likely cause of this behavior?
EDIT:
It only seems to happen after a cold start (car has been sitting for > 4 hours). The outside temperature does not seem to be a factor, it has happened in winter (0F-20F) and summer (70F-90F).
Spark plugs were changed about 3-4 years ago, but I will be changing them today.
Fuel filter might be original, or at least has not been changed in the 6 years I've owned the car. I am thinking of changing this too, but it is a pain in the ass to get to since it's in the tank.
EDIT:
Replaced spark plugs. The car seems to be running better, and have not yet experienced the reported issue (though it was very random, so it may be to early to call it fixed).
UPDATE:
Spark plugs did not solve the problem.
The vehicle is also idling very low (200-300 RPM) once it's warmed up, and occasionally stalls while idling.
UPDATE:
Just had the car to the dealer for a software update, turns out there was a service bulletin that mentioned this type of issue. The car seems to be running better, idling normally, and less hesitation when accelerating from idle.
UPDATE:
Got a new error code that might help find the cause of this problem, P0420 Catalyst System Efficiency Below Threshold. After reading the comment on the answer to this question, I'm starting to suspect the catalytic converter. I did notice a leak near the manifold, so I'm not sure if that would cause the code or if the catalytic converter is really on its way out. Unfortunately the manifold and catalytic converter are a single unit, so I'll have to spend the ~$500 to find out.
Final Update:
Crushing the car and purchasing a new one, seems to have fixed the problem.
Please give more detail on if this happens after cold starts, warm starts or both. In what kind of ambient temperatures (I know right now it is hot, but for the sake of the future readers, give what temp ranges you are dealing with). How long ago were items replaced such as spark plugs, fuel filter, etc. – ManiacZX Aug 20 '11 at 8:23
@ManiacZX: see my edit. – Tester101 Aug 20 '11 at 15:00
+1 for Vrooom putt pa putt pa putt pa vrooooom – Move more comments link to top Nov 8 '11 at 0:32
I love the terminal image:) – Rory Alsop Jun 8 '12 at 17:02
>Crushing the car >2001 Nooooooooooo. It had so much to live for T_T – Robbie Jun 8 '12 at 19:55
this sounds just like a clogged fuel filter to me.
The car starts fine because the fuel has had time to percolate through the clogged filter but once that fuel is used up the engine starts starving for fuel because the flow through the filter is not great enough to run normally.
Since it occurs randomly it will be hard to test this. But I would try slightly depressing the gas immediately when the car starts and see if you get the engine stuttering. I believe with the gas pedal depressed, the fuel line pressure will be greater so that it can push enough gas through the clog to keep running.
Years ago I had a 1989 Mercury Topaz (US) and when I would sit in neutral at a light it would idle fine, but when I shifted into drive the car would suddenly die. The issue was the fuel filter was clogged and when I shifted into drive the engine would expect a sudden increase in fuel but the clog slowed it down and the engine would stall. Tapping the gas pedal right when I shifted into drive solved the problem until I was able to replace the fuel filter.
If the fuel filter was clogged, wouldn't it be less random (and happen more often)? Would I notice other issues, like hesitant acceleration or something if this was the case? – Tester101 Aug 26 '11 at 16:27
I'm fairly sure it is a problem with the fuel air mix, but I'm hoping the recent software patch is the solution. – Tester101 Aug 26 '11 at 16:29
+1 - Even though the OP found an alternate solution. Since the issue is intermittent, it's unlikely to be electrical, meaning it's likely fuel related. I definitely agree. – Sivvy Apr 2 '14 at 21:51
Fuel filter. My car had the same problem, no code but the car had cold start problem. It was at the garage for a day, everything checked out good. Out of frustration the macanic changed the fuel filter. That fixed the problem. PS. I didn't know I had to change the fuel filter. I had 90,000 miles on the car, and it was the original fuel filter. My bad.
It's supposed to be changed after 15k or 30k miles depending on the car. – Juann Strauss Apr 2 '14 at 15:52
My 2000 Cr-v was doing the same thing. I ran fuel injector cleaner through it and have not had an issue. (I ran a lot through it. Only had about a half tank of gas and ran a whole bottle, that treats up to 35 gallons)
Were your injectors noisy? i.e. Did they go "tappa-tappa-tappity-tap"? XD – Juann Strauss Oct 28 '14 at 9:44
I dont know but my mothers 99 accord had the same darn thing wrong. i cleaned out her throttle body twice and she runs fine now.. has an internal fuel filter.. so that couldn't be helped.. only thing left for me to do was clean out the throttle body and or replace the egr.. or replace fuel pump.. I went with the throttle body first to avoid spending 100.00 for a fuel pump and almost that for the egr .. she is happy with the results for the past week no issues.. if this problem repeats the next step I will take is the egr from a used car, if that holds for 3 - 6 months we will purchase a new one.. if not the issue we will purchase a fuel pump new.. I have learned it is best to go to the u pull it place and get these costly sensors "used" to validate a problem rather then spend hundreds on new parts..I work too hard for my money to throw it out the window..
protected by Move more comments link to top Nov 17 '14 at 18:24
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site.
