I have a 1995 Chrysler Lebaron. 3.0L, V6, Automatic transmission.
It has recently developed an issue where as you accelerate, it seems to get "stuck" in third(maybe?) gear. It will drive with that gear stuck for a few seconds, and then shift up. However, if you leave it stuck in that gear and try to slow down, the car will stall.
I have found that some people have had this issue where their Lebaron goes into "Limp" mode, and stays that way. It seems like this may be what happens, but it only stays that way for a few seconds, if I'm accelerating.
A possibly related problem that it developed at the same time is with the Tachometer; sometimes it will intermittently not reflect the true RPMs of the vehicle.
I have replaced the Transmission control solenoid; as well as the output speed sensor.
My questions are as follows: - What could be causing this issue with the shifting? - I suspect the computer being reset might help with recalibration (if that is causing the issue), but attempts to have the computer reset successfully have failed. Is there a way to reset the computer manually?
