Take the 2-minute tour ×
I have an old car (1990 Volvo 240) which I am rather attached it. Lately it seems like it has been creaking and groaning rather more than usual. Is there some sort of spring cleaning(except it's a 20 year cleaning) that I could get for the car and give it a couple more years? I get it its oil changes and I keep up the inspections, but I feel like it could use a refresh.
I'm somewhat clueless about cars, so the whole question may be out there. Can you help me put words to my thinking? Also, if there is some sort of maintenance that fits the description, any idea of how much it would cost?
PS: Any tag ideas?
PPS: 150k milage
You should add mileage so we have a better idea what we are working with here. –  FossilizedCarlos Aug 9 '11 at 21:42
add comment
Firstly, I'm going to asume the bodyshell is sound, as there is no point doing anything if it is rotten (and Volvos of that age can rot very badly) - You'd end up spending hundreds on getting it welded back together...
I'll give an idea of prices in Sterling, obviously costs vary depending on where you are...
Suspension
Creaks and groans are often a symptom of tired suspension. New dampers from companies like Monroe can be obtained cheaply, and will make a lot of difference. Budget for a couple of hours a corner if you're changing them yourself, less if a mechanic does it. The last set I got were £10 a corner off ebay.
Bushes will also be tired and worth changing. There are quite a few, and some will need a hydraulic press to change (which most decent garages should have). Polybushes from someone like Superflex are worth fitting if you intend to keep it a long time, and aren't usually much dearer than rubber ones. Budget around £5 per bush, plus fitting.
Brakes
Hopefully you've been keeping these in good condition, if not then budget for new pads & shoes at least, as well as a fluid change.
Engine
The old Volvo redblock engines go on for ever, but make sure you keep up with all the routine maintenence, such as changing the timing belt, if it hasn't been done recently.
While you're at it, change the gearbox and diff oil, both will be pretty manky if they're original, and you'll probably find both will run a bit quieter with fresh oil.
Interior
Take the seats and carpet out and give them a good proper clean - getting rid of 20 years of built up grime will make it feel like a much better place to be! Tidy up or replace any broken trim, and give the paintwork a bit of attention (e.g. T-cut)
There is plenty more you could do, but I think sorting the suspension and tidying the appearance will make the biggest difference.
add comment
Make sure you have completed all the routine maintenance specified by your owners manual or a repair manual. Specifically Replacing:
  • Belts
  • Spark Plugs, Plug Wires, Distributor, etc.
  • Filters (Air, Fuel, Oil, Transmission Fluid)
  • Drain and fill your Transmission Fluid and Coolant
Additionally:
  • When your coolant has been drained, check and possibly replace your radiator hoses.
  • Test your shocks/struts (this might be some of the creaking)
  • Test your ball joins and grease the rest of the suspension
  • A nice cleaning and a wax can make a big difference on the exterior.
add comment
