Tell me more ×
My OBD shows that I have low fuel pressure in a 1997 Ford Mercury (tracer). Do I have to replace the fuel pump? If so, do I have to replace the whole thing or is it enough to replace just the motor unit? What else might cause low fuel pressure reading?
I am not familiar with a code or a data output that measures fuel pressure on the OBD system. If it's a code what's the code, if not is it a data point that simply says low fuel pressure, or does it give a valve? Also please include the engine size in your question. – Larry Jul 31 '11 at 19:29
1 Answer
Generally speaking (not familiar with that model), it could be due to:
  • Bad fuel pump (fairly rare, fuel pumps are one thing that usually last forever)
  • Clogged fuel filter (has it been changed recently/ever?)
  • Bad fuel pressure regulator (although, they usually fail the opposite way)
  • Leaking fuel injectors (unlikely, would require a pump that's marginal to begin with)
I'd change the fuel filter first, that one is often overlooked... – Timo Geusch Aug 2 '11 at 19:29
