The speedometer on my '94 Suzuki Sidekick wavers sometimes. This seem to happen only when I'm accelerating in about the 40-60 kph range. I think it may happen consistently under those circumstances; at least, I've not noticed that it wasn't wavering. When it's wavering, it does so in a range of about 6-10 kph, at a frequency of probably 2-4 times a second. The frequency and range seem to be pretty constant, I'm just not real sure what they are.
Is this likely to be a symptom of a serious problem? I have no idea how long the speedometer's been doing this.
Mine doesn't waver nearly as much, but I've got a similar-ish issue in my '96 Mark VIII. In that case, the speedometer is also off by about +4 MPH in that speed range. – Iszi Jul 28 '11 at 20:15
If the vehicle has a speedometer cable it may be frayed causing the fluctuating of the needle. It's also possible that the speedometer needs to be rebuilt.
I've seen one case where the cable got loose behin the gauges cluster and was disconnecting/connecting once in a while... Remove cluster and check if it's not frayed as Larry suggested. You can also check the other end of the cable too. – Gabriel Mongeon Jul 28 '11 at 19:50
