I am attempting to remove the window glass from my driver-side front door so I can replace the window regulator. I have removed the two metal clips that hold the glass in the lift plate. Now the window is loose in the lift plate, but I can't pull the glass out of it - it is still holding on somehow. Is there anything else I should have disconnected?
My regulator is stuck at the bottom position, so I have very little leverage to pull the window up (I had to loosen the bolts and raise the regulator an inch or so just to reach the clips).
Update
I got it worked out. I hadn't realized there were pins sticking out of the bottom of the window into the lift plate - window had to be moved laterally (and pretty forcefully), not just up. A mechanic in my area took 5 minutes to come out and help me in his parking lot and figured it out. Props to Auto Doctor in Crofton, MD, for anyone in this area.
