Still working on the 2000 Honda CRV. Trying to get the lock assembly out of the door so I can work on it, but I'm having trouble disconnecting it from the outside door handle.
part #8 plugs into the handle assembly, but I can't see how to disconnect it. Is there a special trick to getting this disconnected, or should I just yank and not be afraid to break it?
Both part #8 and the handle are plastic, so I'm a bit hesitant because I don't want to have to order a bunch of extra parts because I broke them.
Pry it with a small screwdriver, it's just a snug fit. This first picture is what that rod is held in with
Some latches like the one below have a retaining clip that hooks onto the rod, but your's isn't one of them.
Had to take the entire assembly out and unscrew the handle from it, turns out this piece is not easily removed. – Tester101 Aug 17 '11 at 16:07
up vote 0 down vote accepted
Turns out part 8 is not designed to be easily removed from the handle assembly. I ended up removing the exterior handle assembly from the door, and unscrewing part 8 from the lift arm of the lock assembly.
