I am looking for a way to repair a small hole I created in my exhaust. The hole is about 1 to 1.5 inches long and only about the width of a cutting wheel (you can guess how the hole got there). I was considering using a jb weld type product but i fear that it won't fill the hole i created.
Any advice is appreciated, thanks.
up vote 3 down vote accepted
You can use a wrap and clamp to seal the hole. Your local parts store should have such a kit.
Or the better solution would be to weld it shut, or cut out the section of pipe where the hole is, and weld in a new section of pipe to replace it.
as they say, more than one way to skin a cat. thank you for your answers – Mutmatt Aug 26 '14 at 20:05
I'd definitely recommend the welding option. Clamping the hole shut will do little to nothing to strengthen the tube, whereas a good weld will restore it to its original strength. This gets more important the further away the damage is from the closest mounting point. – Mels Mar 21 at 10:39
I think you're looking for something approximately like this, only in the size you actually need: exhaust band clamp
That's how Landrover owners do it! – Juann Strauss Aug 27 '14 at 10:29
