So, I've pulled the codes from my car based on the helpful information provided here:
Check Engine Light on '94 Jeep Grand Cherokee
Now, I need just a little help understanding what the codes actually mean. The translations below are taken directly from the other thread.
12 memory to controller has been cleared within 50-100 engine starts
What particular "memory" is this referring to, and how would it have been cleared? I imagine loss of battery power would be one cause. Is this also the same as the engine code memory? Does that memory get cleared each time it's read?
21 oxygen sensor signal, neither rich or lean detected
I presume this is pretty straight-forward: Check/replace O2 sensors. Although it could sort of be construed to mean that the air/fuel mix is dead-on, I'm sure that's not very likely.
55 end of message
I'm guessing I should see this every time I pull codes? Sort of like this message from the MCP:
END OF LINE
Note: This is for a '94 Jeep Grand Cherokee, 4WD, 4.0L in-line 6 cylinder engine.
2 or 4 wheel drive, and which engine? – Move More Comments Link To Top Jun 20 '11 at 18:52
@Larry Updated OP. – Iszi Jun 20 '11 at 18:58
up vote 2 down vote accepted
I found this:
http://www.justanswer.com/chrysler/1l50u-does-dtc-12-memory-controller-cleared-within.html
Which seems to confirm that 12 just means the battery was disconnected and that you should always see 55.
21 should not come up unless there is a problem, because the sensor should be able to detect rich or lean. So check/replace O2 is the correct course of action.
Worked for me. Thanks. – Iszi Dec 22 '11 at 15:01
