I bought my car in February 2013 with 49K miles. It now has 61K miles on it and my brakes are starting to squeak very gently, until I apply more pressure on the brake pedal.
When I bought the car, I foolishly didn't ask for any service / maintenance records, so I have no idea how old anything is. I'm assuming everything is the original OEM hardware when the car was first purchased. The rotors are pretty rusted around the hats. I know the general consensus is to replace the rotors along with the pads, or at least to have them resurfaced, but what about the calipers?
I've never actually had to replace the brake pads on either of my previous cars, so I really don't know much about the experience...
Calipers and brake pads are not the same thing, so the end of your question is a bit confusing. You don't need to do anything with your calipers unless there is something mechanically wrong with them. Your brake pads are a wearable item and may need replacing if they're wearing out. – Ellesedil Jul 9 '14 at 15:01
@Ellesedil Well, I know they're not the same thing, I just assumed that at some point I'd need to replace them. – sab669 Jul 10 '14 at 19:20
Calipers are normally designed for the all car life. Front discs shall last for approx 80 000 km mileage in avg, and friction pads for 40 000 km mileage. Rear discs and pads shall last double of the front axis ones, if the car is driven unladen. – hornetbzz Nov 29 '14 at 4:33
The noise you are hearing is more than likely the squealer on the brake pads. The squealer is a little metal tab which is incorporated into the brake pad. When they wear down "so much", it starts riding upon the rotor, which causes it to squeal. When you step on the brake, it will stop making noise (until the brake pad is so thin it will start grinding on the rotor and making noise). With ~61k on them, this sounds reasonable, depending on the driving habits of yourself and the previous owner. Your idea to change the rotor and pads is spot on. As cheap as rotors are these days, replacing them only costs a little more than turning (resurfacing) them. You can inspect the pads to see how much meat is left on them. If they look thin, this is definitely the issue.
As for the calipers ... if they are still working (not seized) and not leaking, you don't replace them. They will usually last for a good long while (a couple hundred thousand miles or more).
Ah, I didn't realize they can last for basically forever. My roommate recently took his car to have his brakes done and they told him he needed new pads, rotors and the calipers. Think they wanted like $1400 or something, so he went elsewhere and just did the pads and rotors at their recommendation. – sab669 Jul 10 '14 at 19:28
@sab669 ... You can usually expect calipers to last the life of the car, unless you are talking cars which get ultimate mileage. But, yes, they usually last a long time. – Pᴀᴜʟsᴛᴇʀ2 Jul 10 '14 at 22:23
Brake pads last longer if you drive slow and brake gently or wear out quickly if you drive like Dominic Toretto. So it's dificult to give you a hard and fast rule regarding mileage. If you hear a squeal from your brakes, it means that the friction surface on the pads are too thin. You could probably drive another 1000 to 2000 miles with them in that condition if you're broke or in the middle of the desert (for some reason). But There is a tiny piece of metal on the brake pad which causes the squeal to tell you that you need to change them soon. It's a safety feature like your fuel light. It starts warning you that your running low on fuel, or friction surface, as the case may be.
Caliper replacement does depend on the mechanical function, but for the life of the vehicle, guess that depends on where you live, pot holes, salt and sand beat up the calipers. In New England and areas where winters are harsh, you will find 5-7 years and they will need replaced depending on the vehicle and its use. In reducing the weight of the vehicle aluminum calipers are more popular and they do not last as long, generally because of the aluminum caliper and steel mounting components, the dissimilar metals do not perform well over time. Also rear calipers in some vehicles have more intricate parking brake and piston subassemblies that are contributors to failure rates. So making a blanket statement seems misleading.
Also today most rotors cannot be resurfaced, again to reduce weight and increase mileage there is just not enough material to turn them down to provide a smooth surface.
If your disks have started to develop new or deep circular scratches its time you change the pads. Try to feel the disk and you'll know if it really needs a change. Don't compromise on safety.
In general, if one brake pad wears out, and the other looks new. When the caliper fails it can sometimes make pressure on only one side. Also, if the Brake Pads on one SIDE of the car wear out significantly faster than the other side.
