I have new radio and AC units for my 2001 Subaru Legacy L Station Wagon but I do not know how to install them. It seems more complicated than I expected. Does anyone knows of a good tutorial or manual on how to remove and replace those two?
What part of the AC unit are you trying to replace, the compressor? If so, there are a few specialized tools you'll need to complete this. Such as a vacuum pump and an A/C manifold to check pressures, to name a couple. If you don't have these and really don't know the process, I'd highly suggest you take your work to a qualified shop. Not something an average backyard mechanic can attempt and complete successfully. – ᴘᴀᴜʟsᴛᴇʀ2 Jun 11 '14 at 16:48
The radio is a piece of cake, to be honest. The hardest bit is popping the dash without scratching it, but then it's obvious. As far as a/c goes, the dash module is as easy as the radio, but as Paulster says, replacing the actual guts of the thing is not for beginners. – Rory Alsop Jun 11 '14 at 17:34
up vote 0 down vote accepted
As far as the radio goes, you can use this tutorial. If you just want to replace the AC front panel box I am sure you can figure it out using the same tutorial. But as said in the comments, if you want to work with the AC unit itself, better take it to a shop.
