I'm wondering if there is any benefit behind double-clicking when using a mechanical torque wrench. Could it be that some folks do it to compensate for slack in the ratcheting mechanism?
In other words, would I lose anything if I torqued down with just a single click?
This YouTube video demonstrates what I mean.
up vote 9 down vote accepted
Double checking your torque is never a bad thing. The only thing you lose is a half second of your time. Peace of mind is what it's all about.
One of the reasons for doing this, though, might be when you are torquing, the fastener itself becomes slightly bound up, not giving a perfectly correct reading. By double clicking, you are allowing the fastener to rest for a second, then you are back at it to get the proper amount of torque there. This is the only other reason besides habit I can tell you why someone would do this. I almost always double check my torque, but usually only when I'm doing something in a sequence. I hardly ever double click while I'm applying torque unless there is only a single fastener involved. It doesn't mean either method is wrong or right, just that people have different ways of doing things.
Of note, remember that when torquing with a click type torque wrench, you can easily over torque your fastener by doing things too fast. You can go by the torque setting of a click type torque wrench without even thinking about. Slow, methodical movements are what you want to achieve. You want to be just on the verge of stopping the twisting motion at a moments (clicks) notice. Too often while at a tire shop (Merchants, NTB, whatever), I'll see the guys rocking the car to assist (well what they think is assisting) in the torque process, which will actually over torque a lug nut without too much issue. The only time I'm sure they are giving it the right torque is when I see them using a torque stick, which provides only one set torque value. These tools give way when the proper torque is achieved, insuring you cannot over torque. I will most often loosen and retorque my lug nuts after I get home just to ensure it was done correctly ... at which point I find that most of them are torqued all over the place, only proving my point.
Thanks for the detailed answer. Just curious as to how you determine that the lug nuts are torqued all over the jungle. Do you do it with a mechanical torque to gauge the torque of each nut, judge it by feel when undoing them, or use something else altogether? – Zaid Jun 10 '14 at 2:40
Actually, I loosen all of the lug nuts and retorque them correctly. While I do not have a "calibrated arm", it's pretty easy to tell when you loosen them that the torque is all over the board. It doesn't bother me if the torque is too tight (as long as it's not too tight) as long as they are all torqued equally. The two reasons you torque the lug nuts in the first place: so the wheel stays on; help prevent warping of the wheel. – Pᴀᴜʟsᴛᴇʀ2 Jun 10 '14 at 10:28
I spent 25 years as a Helicopter technician, and from year one i was Ordered NEVER EVER to double click a torque wrench. This double clicking that i see mechanics do drives me nuts. You are "overtorquing" if you do it twice.
Do you have any references on this? – Pᴀᴜʟsᴛᴇʀ2 May 7 at 2:24
I agree with the "no harm" part, but double-click is useless because overcoming the now static friction load from the clamping force will be much greater than the first pass with the fastener already in motion. Some folks not only double-click but add a bit more -- what I call Angel's Share. In that case, a tiny modicum of "harm" (or at least inaccurate torque) is imputed. None of this matters relative to the tragic jobs some tire shops/technicians perform. When the rack is out of blue 19mm torque sticks, away they go with the 1/2" at 125psi, because they all just "know" when to stop. – SteveRacer Jun 12 at 19:20
